Rpms at 3,000
Jodygoodwin704
4
High shoals
Ford ranger
None
None yet.
15 inch
I have a 90 2.3 liter that is running at 3000 rpms. Any ideas as to why this is happening? I am going to change the iac valve to see what will happen.
rusty ol ranger
2.9 Mafia-Don
8,553
Michigan
177 CID
More then likely the IAC is stuck open.
Or you got a hellacious vaccum leak
Jodygoodwin704
4
High shoals
Ford ranger
None
None yet.
15 inch
I will check that out. I will also clean the map sensor as well. Thank you.
scotts90ranger
5,264
Dayton Oregon
2.3 Turbo
It's not going to be a sensor, it's getting air so most likely the IAC is stuck open or the throttle cable is sticking open a little.
Rick W
October Truck of The Month
25th Anniversary Merch
