rough ride
redblazerx78
6
spartanburg, SC
ranger
I have a 93 2wd splash, not lowered. It rides rough and is bouncy, I just put good shocks on it and its still a lil rough.
Could the springs be shot at 265K?
I dont know what else to replace.
8,370
Did you bounce it when shocks were off?
That would give you an idea of how stiff the springs are
First defense against a stiff ride is tire pressure, tire maker may say 32psi but its YOUR tire, so try 28psi
Tires absorb the smaller bumps, over-inflated tires cause harsher "feel" to a vehicle
Springs are rated for the weight they need to support, its called "sprung weight", in cars that's pretty easy to calculate, weight on each axle plus 4 passengers spread out between the two axles
Pickup trucks are often over sprung, because they have a 1/2 ton rating for the bed, so they have springs rated for the weight of the rear of the truck PLUS 1,000 pounds more
So when bed is empty they are very stiff
Springs work by the weight they support being enough so that the spring flexes when you hit a bump, the weight of the vehicle above the spring holds the top of spring in place so bottom can go up and down absorbing the bumps
If spring has too high a weight rating then when you hit a bump spring doesn't flex/compress, it just pushes the vehicle up, so "stiff ride"
That's what can occur in the rear of a pickup truck
Shocks do not hold any weight, they are there to prevent a spring from continuing to bounce after hitting a bump
So with shocks not connected when you bounce the corner of a vehicle it should easily be pushed down and come back up, same reaction if wheel in that corner was pushed up, easily deflected up, like when you push body down
If you can't easily push down on a corner with your 150+ pound body weight then that's the ride you will have, stiff
Shocks can't change that
It cheaper for truck makers to put in a set of leaf springs rated for the full 1,000 pound extra weight
So that's what most pickups have
YOU can get lower rated leaf springs with an added overload spring to get a soother ride when bed is empty
OR
YOU can add weight to the bed until you are satisfied with the ride, although MPG will be less hauling around the extra weight, lol
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Not sure what you drove before the '93 Ranger, but the truck is almost 30, and trucks back then didn't drive/ride like trucks do today.
sgtsandman
Aircraft Fuel Tank Diver
12,637
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
What tire pressure are you inflating your tires to? Use the number marked on the sticker that is stuck on the door jam or the door, not the max pressure number on the sidewall of the tire.
I’ll 2nd the remark about old trucks vs new trucks when it comes to ride. If the tire pressure checks out, it’s probably just how the truck is. Trucks don’t ride like cars because they are sprung to carry a load and not have the rear end sag.
