Rod ends etc…
DRanger024
83
Dale, WI
~4" front, 2" rear
32X11.50-15
So what are your favorite and why? Like in depth why. I have 1.25” QA1 rock ends on my ‘94 and I do not approve. Drivers side has been awesome for 18+ months but the passenger side has been cooked to death by the catalytic converter and creaks. It’s super annoying and when I take it apart to service it, it looks great other than some dry grease. So I want to know, what do you prefer?
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
Forum Moderator
7,245
SW Iowa
I just have rubber ones from Napa.
Poly ones are great but get creaky with age as the grease deteriorates.
scotts90ranger
717
Dayton Oregon
2.3 Turbo
4x4 Junkie says to just use the stock style, and with his experience and experimenting with dang near everything I trust him... plus the factory style bushings haven't let me down and have taken some serious abuse... hitting that log at 15 in the ditch lengthwise with just the passenger side tire years ago was enough for me to be convinced... stuff got all tweaked but I just straightened it out and put new bushings in, or did I reuse them? I don't remember, I've got all sorts of spare parts around...
rhekman
9
Lakes Country, Minnesota, USA
2"
Do your QA1 ends have the PTFE/Kevlar bushings? Or the polyurethane ones?
Sorry I don't have anything to add, but I'm building new arms this week and I went with Rock Jock 2.5" Johnny Joints. I went oversized on purpose to allow for more damping, and the Johnny Joints are greasable. I was also contemplating making an extra air gap heat shield on the passenger side to protect from converter heat, so I guess this thread is another point in the yes column.
The stock bushings lasted 20+ years, which I can't argue with. However the way I use the truck now, I'd like less deflection and more bind-free suspension travel. So one bolt and a couple snap rings to rebuild each side seems like a worthwhile tradeoff for less bushing life.
DRanger024
83
Dale, WI
~4" front, 2" rear
32X11.50-15
Mine are the PTFE ones. I would think polyurethane would melt next to the cat. I’m thinking something greasable will be going in next. I don’t care if I have to squirt grease in every 1,500 miles as long as they’re quiet. As far as stock style bushings go, it’s easier to make brackets for rod ends IMO.
ericbphoto
Overlander in development
Forum Moderator
5,939
Wellford, SC
6"
I would recommend fabricating a heat shield. Even the OEM assembly had that little cup-shaped heat shield.
