Repositioning Caliper on a 8.8
Roert42
4,939
Kintersville, PA
Ranger XLT
4.0 SOHC
I agree with eric, if you put a winder axle in it you wouldn't have to worry about any clearance issues with the frame at all. A F-150 has a wider 8.8 then an Explorer or Ranger.
17,753
SW Iowa
Drums might get you a little more clearance but I don't think it would be much. Enough that it did clear as you flexed the suspension in your shop it would probably still hit as things shift around on the street.
Junk Collector
Truck of Month
4,769
Rapid City SD
I think you could possibly turn the backing plate and caliper bracket and redrill the mounting holes on the axle housing. I don't think that rotating a bit would affect bleeding.
You could also dump the Explorer brakes completely and use a weld on aftermarket caliper bracket... Pretty common to do that on Ford 9" axles for disc brake conversions. I think we used GM calipers of some sort for that back in the day... Real easy.
scotts90ranger
4,305
Dayton Oregon
2.3 Turbo
It's been a while since I've been that deep into one, I'm with Shran, rotating it a few degrees and redrilling shouldn't hurt anything. I spun an axle tube but I think it was the other direction... and it wasn't on purpose... :)
