Replacing fuel filter - 1990 2.9L
Erikinho
4
Chula Vista, Ca.
Ranger ECAB
"Be quick to listen and slow to anger"
So, after replacing my TPS sensor the motor still has hesitation when depressing the accelerator pedal... I am now going to replace the fuel filter... I did a little research to familiarize myself with the procedure by watching a YT vidoe of someone doing this replacement... The only thing I see is to plug the fuel lines with something as soon as they are removed from the filter to stop the fuel flow... Here's the YT video:
Any advice welcome! Looks fairly straightforward... I will be raising the driver side where the filter is located and placing a jack-stand underneath before performing the operation... I wonder how easily the fuel lines will come off...?
Uncle Gump
Token Old Guy
13,458
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Use a drain pan for sure. Be easy on the clips... they get brittle. Wouldn't be a bad idea to just buy new ones before you even start.
rusty ol ranger
2.9 Mafia-Don
7,493
Michigan
177 CID
Pull the pump relay and start the engine till it stalls...that way you dont have fuel under pressure spraying around
Junk Collector
Truck of Month
4,800
Rapid City SD
A lot of new filters come with clips - wouldn't hurt to check the box before you pay for it.
Keep some rags under the truck with you to clean up spills and keep your face away from that general area when you pull the lines off.
Erikinho
4
Chula Vista, Ca.
Ranger ECAB
Thanks! The new filter comes with new clips!
Erikinho
4
Chula Vista, Ca.
Ranger ECAB
Direct me to wear the connector is for the pump relay...? Thanks!
rusty ol ranger
2.9 Mafia-Don
7,493
Michigan
177 CID
On a 86-88 its on the passenger side fender under the hood....i cant recall the color....i think its the green one.
On a 89-92 i have no idea.
