fourwheelford
- Jul 24, 2009
- 1
- washington state
- ford
- Engine Size
- 3.0 Flex
Hi all, first off 2000 ranger 4x4 with a 3.0 FF 111,000 on the clock.
Ok heres my issue I bought the truck a couple years ago with a lift on it, it was my first truck and at the time I liked the look of the lift but now time has passed and the ride is getting worse and parts for the lift (bushings and what not) are not being made anymore. I took it to a 4 wheel drive shop and the guy said it was a trail master lift kit. Its poorly designed and causing the ride to be really crappy. Everything is bolt on as far as I can tell, im a fabricator so im sure nothing has been modified frame wise.
Basically I want to remove all components of the lift and bring it back to stock ride height but I need to know the stock parts that are removed in order to put the lift on so I can track them down. Just a list of front end components would help me narrow it down to what I do and do not have. My steering rack needs to be replaced so thats happening along with the shocks and all front end bushings once it comes off. Also My tires are 10.5 by 31 and I put a superlift after market driveshaft for lifted rangers and I need to know if those can still be used at stock height.
I have only looked under a couple stock rangers but as far as I can tell the lower control arms bolt to the frame and there is no stock cross member under the front diff I think with new nuts, bolts, washers, bushings and shocks I can have this thing finally riding good. Any info would be great thank you everybody.
