Remove Evaporator Housing without Pulling Heater Hoses
8thTon
--- Banned ---
806
Pennsylvania
My AC has leaked since I got it, and it was filled with dye then too. I've never been able to see any leak though. I replaced the accumulator and seals because it was easy, and it blew cold for a week or two and then leaked down again. So now I want to try the evaporator since a leak there would be hidden (and it kinda had that smell in the cab too).
So if I remove the air filter and the coolant and washer reservoirs, and perhaps the fan, can I get the housing out without disconnecting the heater hoses?
Junk Collector
Truck of Month
4,797
Rapid City SD
I've swapped complete AC systems from donor trucks into others in the past and I'm pretty sure I had to remove the heater hoses to get the HVAC housing out. I also had to drop the inner wheel well liner. That was in older trucks though.
I THINK maybe since you're just removing the evaporator, MAYBE you could remove the wheel well liner and sneak the HVAC housing down and out rather than up and out like I did.
