Remanned engine questions
yardy_b
Las Vegas
Ford Ranger xlt
I'm having some issues with my Ranger. My check engine light will not go off and I have been fixing problem after problem, but it just won't go away. I've decided to get a remanufactured engine to replace my current one and my question is if I buy one, does the remained engine have to come from the same model Ranger or does it matter?
MikeG
752
central Texas
B4000
2"
235/75r15
So what codes does it have and what did you do to fix it?
yardy_b
Las Vegas
Ford Ranger xlt
I don't remember the codes off the top of my head, but one is a cylinder 5 misfire and I replaced all the spark plugs. I don't remember the second one.
97RangerXLT
3,841
Fishers, IN
2"
31"
Get a list of the codes, generally a check engine light is not indicative of an engine failure, and there are many things that will cause a misfire other than a spark plug. How are the plug wires? Coil pack? Injectors? Give us the codes and any other symptoms before blowing a few
grand on a reman engine that may not fix your problem
Also do a compression test on all 6 cylinders (or 4)
AJ
Kirby N.
March Truck of The Month
