bshun
- Oct 6, 2024
- 0
- Mass
- Ford ranger xl
Hi , I'm having trouble identifying a relay and connector that is bad so I can replace it. Engine compartment passenger side right under the starter solenoid in between the battery and the vacuum ports is a 5 pin relay with a brown connector. Wiring harness on that side should be for the emc but when I look the ecc relay has only 4 pins. So it can't be right. Someone jumped a wire on it before i owned it and now the connector is corroded and needs to be replaced.
Only relay I see online with 5 pins is fuel pump relay but mine is mechanical.
Im still learning and in need of help. I have all the books and can't find anything.
