gezitz57
- Sep 19, 2021
- 0
- Georgia
- Mazda B2500
I have 1999 Mazda B2500 that I rebuilt the transmission about 36K miles ago. Worked flawlessly until the transmission cooler line in the radiator cracked and the transmission was filled with coolant. Tore it back down and rebuilt it again to get all the coolant out and all worked fine. While I was in there I replaced the solenoid wiring harness because the wiring insulation was deteriorating. Recently the ABS light started coming on all the time. Drives and shifts fine with the OD "on", but if you click the OD "off" it will not move forward or reverse. It acts like one of the solenoids is applying pressure and locking the transmission up. Turn the OD back on and it drives fine. I replaced the axle ABS sensor but this did nothing. I also checked the resistance of all the solenoids and all are within specification. Could it be the ECU? I don't want to just buy one if its not needed. Any help will be greatly appreciated as I am stumped.
