rebuild 4.0 engine at Brazil
GabrielBR
Anápolis-GO Brazil
FORD
Hello!
I have to rebuild my engine, because the previously owners didn't changed the oil at the correct time, so, there was lot of grease at the upper part of the engine.
The lower engine part is ok, the crankshaft dind't lost lubrification, neither the conecting rods, but i have to change a good part of the engine, such as pistons (1mm over), conncting bearings, exaust valves, rocker arm, valve lifter, push rod, and timing chain kit.
To have a low cost, i will buy this parts at USA and bring it to Brazil, and the store I chose is the ROCKAUTO, just because it sent to Brazil and aparentely have a low cost.
Finally, my questions are, are the parts that I have chosen ok, I mean, are they reliable?
Is there another website that you guys indicate that have a good price? Can be a fisically shop too, at the region of Massachusetts, Leominster.
3,580
For general repair I use Rockauto to buy parts.
If I am doing a whole engine rebuild I usually buy the parts from NorthernAutoparts.com. They have whole engine kits for decent prices, but I don't know if they ship international.
GabrielBR
Anápolis-GO Brazil
FORD
I forgot to mention, this are the parts that I need to buy!
Engine : Piston
ENGINETECH P30456 Set Info
Dish top 0.330" deep x 3.130"; 1.450" CH; Hyper; Use M39516 rings
$20.79 x 6=$124.74
Engine : Piston Ring
ENGINETECH M39516 Set Info
Premium. Ductile top. 1.6 / 1.75 / 3.5mm.
$28.79 1= $28.79
Engine : Connecting Rod Bearing
ENGINETECH BB625J Set Info
No. Brgs: 6; Shaft Dia: 2.1251-2.1260"; Hsg Bore: 2.2370-2.2378"; Width: 0.649"; Wall Thickness: 0.0548-0.0553"; Oil Clearance: 0.0008-0.0030"
$12.74 1=$12.74
Engine : Crankshaft Main Bearing
MAHLE/CLEVITE MS2006A Set Info
A Series (Aluminum)
$38.79 x 1=$38.79
Engine : Exhaust Valve
AENGINETECH V2427 Info
.3153" stem. 1.360" head.
$3.86 x 6=$23.16
Engine : Engine Kit Gasket Set
SEALED POWER 2601699 Info
Head bolts not included.; PermaDry molded rubber oil pan Gasket. incl.; Premium valve stem seals incl.
$102.79x1=$102.79
Engine : Rocker Arm
MELLING MR927 Info
$5.88 x 12=$70.56
Engine : Valve Lifter
ENGINETECH L2128 Info
Hydraulic. Roller follower.
$13.27 x 12=$159.24
Engine : Push Rod
MELLING MPR471 Info
$3.76 x12 = $45.12
Engine : Timing Chain Tensioner
ENGINETECH TT345 Info
(Only 9 Remaining)
$21.79
Engine : Timing Chain Guide
ENGINETECH TG261 Info
(Only 2 Remaining)
$5.86 x1=$5.86
Engine : Timing Set
ENGINETECH TS4172A Info
3pc. set. Single roller chain. Does not include guide or tensioner. Use guide TG261 (Only 8 Remaining)
$20.99 x1=$20.99
Engine : Cylinder Head Bolt
ENGINETECH HB122 Set Info
$20.89
GabrielBR
Anápolis-GO Brazil
FORD
Thank's man. I don't need a shop that ships international, my main problem is that I don't know which brands that are listed above, whose are reliable.
Enginetech for exemple, we don't have this at Brazil, so I don't know if I can use it without future problems.
About northern auto parts, I took a look at the engine kits, but there are some pieces that I don't need (cam for exemple), and are others that I need and they dont have, like 1mm pistons. So I think that they aren't a solution for my case.
P.S. Do you Know any flat piston that I can use at the 4.0l 95 Ranger? If I find any solution maybe I could change the stock one, so It would be better to use with Etanol (more tax of compression)
P.S. 2 Do you know a cam that fits at this engine, and have more torque and speed for daily use (Original fuel injection)? Is there a ready recipe for this engine?
Thanks again!
