Rear differential making noise... sometimes
Ryry
United States
Ford ranger
So I lifted my truck off the ground because i suspected I had an issue with my rear differential. And when I spin 1 wheel (right side) it makes a clicking noise. It doesn’t happen while I drive though. What do y’all think it could be? (4.10 ratio/open differential)
ericbphoto
Overlander in development
16,593
Wellford, SC
3.0L
6"
Are you sure the noise is coming from the differential and not the wheel? Does it happen when you spin the wheel in the other direction?
Ryry
United States
Ford ranger
Well I’m able to spin both wheels freely in any direction I want at the same time. Sometimes it grabs and spins the other wheel, sometimes it doesn’t (when it’s in neutral lifted off the ground), sometimes it grabs and the driveshaft spins too. But to answer your question, it happens in whatever direction I spin the tire.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
It may be normal, when you spin one wheel it causes the differential side gears to walk around the spider gears because the ring gear is stationary. It wouldn't hurt to pull the rear cover and take a look, the fluid could stand being changed anyway.
1990RangerinSK
1,312
Saskatchewan, Canada
Your wheels should only spin in two directions: clockwise and counterclockwise, on a plane parallel to a flat surface created by the sidewall of the tire. If they're spinning in any other direction, you have more problems than you thought you had.
I'm sorry. I couldn't resist.
McWillies
9
Ford Bronco II
Have you checked the brakes? Spring might've popped loose. Otherwise I'd say pull the wheel off and spin the hub by itself, bearing could be going out and it gets mad when the weight of tires are drooping down.
