- Dec 14, 2008
- Reaction score
- 79
- Location
- Mich
- Make / Model
- ford
- Engine Size
- 2.3turbo
- Manual
The problem I see with your plans to use a factory Ford MAF system is your still stuck using the stock size injectors and you still have to make some kind of boost referenced fuel pressure regulator or FMU to raise pressure under boost. Personally I think this is a perfect project to run a Microsquirt system on. Id call Stinger Performance or EFI Source and explain what your doing with that motor and they can set you up with a ECM that will plug directly into your original engine harness. Then you can swap in any size injector you need and have the ability to tune it yourself perfectly not to mention all the other greatly beneficial options offered with MS
