Real Speedometer Issue, Please Help...
MikeGuevara
3.0L V6 183CI
Alright, both my speedometer and my wipers went out at the same exact time around the end of last year. The wipers aren't a problem right now, but the speedometer is. And before you reply, the answer is yes to the following:
- It's not the ECU (I swapped my old one in and it still didn't work)
- It's not the gauge cluster (I swapped it old and put a different one in that didn't work either)
- I installed 2 new ABS/VSS sensors to rule out a bad one from the store
- The guys at the shop put 10 hours into trying to figure out why it doesn't work
Here's what I really need, I need to know what the ABS/VSS is connected to; running through; etc. starting from the sensor in the differential and running into the gauge cluster please. The names of any modules; boxes; relays; etc. would be greatly appreciated also.
1998 Ford Ranger XLT Flareside 3.0L V6
