Rattling shaking sound
Low
Co
Ford ranger xlt
Rattling vibrating sound under the hood,, only in low rpms under 2000, and only in 1st and 2nd gear. I can't visibly see anything loose under the hood or below.. Any ideas?
55trucker
183
Oshawa, Ontario
mild
Sounds like somehow Bill Haley & the Comets got under the hood.
*I said, shake, rattle, and roll*
Catalytic converter heat shield?
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I always check the belt tensioner and idler pulleys.
Low
Co
Ford ranger xlt
Thanks for the feedback. I'll take a look at it today
rhekman
35
Lakes Country, Minnesota, USA
2"
1991, 4.0.
If it's only audible at low speed under load, it could still be something in the accessory drive, or you could also look for loose brackets around the motor or exhaust that contact when the engine twists on the mounts.
If it's the same quality of sound every time, you can search for it while parked by using a long screwdriver or metal rod as a stethoscope to your ear while touching various parts around the engine. Be VERY careful of spinning belts & pulleys, don't wear loose clothing, and be safe. But you'd be surprised how quickly you can narrow down where unusual sounds are coming from.
Low
Co
Ford ranger xlt
Really appreciate the feed back guys, ill try the stethoscope method this morning before work
