Rassen Frassen E- brake
Andy D
8
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
I have replaced all the brake parts from the backing plates out even the rear E- brake cables. I did tighten up the adjustments on the shoes but the E- brake barley grabs and does nothing at all in reverse. Do I just tighten up the shoes some more or did I screw some thing up? TIA
Rock Auto 5% Discount Code: 70D65189E6D8FF: January 5th, 2022
55trucker
83
Oshawa, Ontario
mild
With the drums off & you kneeling down alongside the drivers side chassis and pull on the cable assembly under the drivers door do you actually see the drivers side shoes expanding & retracting?
