Crank sensor has nothing to do with the starter working or not, there is no connections in the wiring between those circuits. Bad starter or solenoid.
No start is sounding like the crank sensor. I fixed this exact problem on my 94. Would run and run with no issues, then just flat out not start, then it would, and wouldn't. Easy sign is if you have a tachometer, if it doesn't move when cranking at all, it's a bad crank sensor. On your '98, you can get to the sensor from the out side, on my '94, it's behind the timing cover, so half the front of the motor has to come out. I was chasing my fuel pump for months. No start, fiddle with pump wires and relay, would start. Ultimately it was the crank sensor.
Gave in and tore down the front of the motor to get to the crank sensor. Was cracked in the epoxy on the back of the sensor. Replaced and has never not started since. Been over a year. Repop parts are just junk.
I had replaced the carbon brushes in my alternator, worked for a while, then didn't. China parts. I have no idea what the brushes were made of, but were not carbon, they slowly cut into the contacts on the rotor shaft, 'brushes' were not worn at all.
