ford_ranger12
- Jan 16, 2012
- Reaction score
- 2
- Make / Model
- ford
- Engine Size
- 5.8
- Manual
I have a 2003 5.0 ranger edge. I swapped in the T5 and used an older ranger master cylinder and universal slave. To use the older ranger master I had to drill holes through the firewall to mount it since the 98+ rangers master snaps into the pedal assembly itself. That lasted awhile but it finally busted through and ruined everything. I got it going by using a piece of steel plate on the inside to spread out the pressure but I'm looking for a permanent solution.
So would an 05-10 mustang hydraulic throw out bearing work on a T-5? (I'm pretty sure these year models came with the T-45)
And would it fully engage the clutch with my stock ranger master cylinder which is a 5/8 bore?
Any info is appreciated. I always try and get some answers first but usually end up diving straight in and dumping money.
