Ranger Shocks
Handy
Montana
I have a 2000 2wd ranger with coil suspension. My shocks need to be replaced, however the part called for at my local auto parts stores call for a 13 3/4" extended length and a 2 1/2" bolt pattern. The shock that is currently on my truck is a 15" extended length and a 2 7/8" bolt pattern. The # PO147B Motorcraft is stamped on my current shock which no one can find or cross reference. Has anyone out there had this problem? If so what did you do to solve it.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The auto parts store probably tried to give you the shocks for a torsion bar suspension.
Handy
Montana
No we looked a that and the mount was wrong.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Go to a different parts store?
Handy
Montana
Been to Napa, Orelley, Carquest, and Autozone
Roert42
4,950
Kintersville, PA
Ranger XLT
4.0 SOHC
You don't just blindly order parts off rockauto?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Only thing I can think of is someone put the wrong shocks on at some point before.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The only thing I see, is for some reason ford specs a different shock for regular cab and super cab trucks. And it specs a build date. You may need to ask for an earlier or later year. Ford does have a habit of changing parts in the middle of a build year.
Handy
Montana
The big problem is finding a 15" extended length and the 2 7/8" bolt pattern. The only thing I found was for a 2500 chevy without the dust cap. Where did you get the screen shot from?
Handy
Montana
No I looked there too but they didn't show specs.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Google Ford parts giant. That's where I got the screenshot. They sell oem ford parts and list all the ford part numbers as you can see. Check the build date on your door tag and go from there.
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
on my 2005 those did bolt on, but were too long
I had to shout COIL SPRINGS for a few minutes before the correct shocks appeared.
sgtsandman
Aircraft Fuel Tank Diver
12,592
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Another place to check is Tasca Parts.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I farted
