• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
Ranger LB trailer, what frames fit?
Ferris Bueller
New member
Near St.Paul
A gal at work backed into the RR corner of my 09 Ranger white longbox. I got a $1239 check from her insurance co and bought another 08 white longbox at a nearby salvage yard. I can still get the original panel fairly straight but will put the replacement box on my 09. I would like to find someone scrapping a longbox 2wd Ranger so that I can use the frame to make a trailer. I plan on putting my 09 box on it. How many years back longbed Ranger frames can my 09 box bolt on to?
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
scotts90ranger
Well-known member
317
Dayton Oregon
2.3 Turbo
1983... seriously
If you are going to make a trailer out of it, go to a local scrap yard and get a used trailer axle and a couple sticks of 4" channel iron or whatever they have that looks frame like, ranger frames are a bit beefier and heavier than needed for trailer use.
snoranger
Forum Moderator
ASE Certified Tech
4,124
Jackson, NJ
'79,'94,'02,'17
All Fords
What kind of moron would build a trailer out of a Ranger bed? :D
country0001
Active member
14
Stillwater, OK
Ford,Ford
4.0,5.0
If you don't have a welder, how do you plan on welding the hitch on?
armadillon
New member
10
Austin, TX
Well, you got your answer. But agreed, you will have to weld the tongue on anyway; safe to say you could use the bed and find the c-channel and trailer axle. Might even be cheaper that way.
Ferris Bueller
New member
Near St.Paul
I did this once years ago by notching the insides of the frame just ahead of the box and then bending it in after a friend heated that portion with a torch. Then an "A" shaped hitch coupler gets bolted to the frame. All welding is then done at a local welding shop. I'll get a welder some day but don't have the money for one right now. I have always wanted to have a trailer that is an exact match to the truck that was pulling it. I have a friend that is in a wheelchair and he wants help hauling in some scrap this summer. His family used to have a farm. His dad passed away a few years ago and has a large pole barn full of stuff. My friend offered to split the $$ from the scrap hauled in. That sounds like a good deal to me since scrap is way high right now. My F250 is broke down and I don't have the money to fix it right now.
scotts90ranger
Well-known member
317
Dayton Oregon
2.3 Turbo
look in his sig, he has a ranger trailer bed, was sarcasm.
snoranger
Forum Moderator
ASE Certified Tech
4,124
Jackson, NJ
'79,'94,'02,'17
All Fords
