Ranger Camper
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,812
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
Europe gets all the good stuff.
sgtsandman
Aircraft Fuel Tank Diver
12,380
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
We have a few here. Hard to find for sure but you can find them. I don't think any of them are that fancy though.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,526
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
17,488
SW Iowa
The US has had Ranger sized slide ins since pretty much the beginning and they still make them.
Popups are more common because both wind drag/weight is less and have a lower CG which is good for a smaller pickup. Even a F-150 can easily get overwhelmed by a hardside.
I have a copy of the "1985 Ford RV and Trailering Guide" that gives all the specs of what the Ranger could handle with what options back in the day. New versions are online.
I have a Skamper for mine, link is in my sig.
sgtsandman
12,380
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I agree most of the ones I’ve found are of the pop up variety. Only one was full height/hard side and it was the old boxy style with aluminum skin. If I were to get one, I don’t think I would want a hard side.
With only a 5’ bed on the 2019, it probably would be worth anyone’s time to make one. Pulling a camper would be the better option.
17,488
SW Iowa
Actually the '19 owners manual specifically does not recomend installing a slide in. I think because the axle is clear to the front of the bed. Supercab manuals are different.
sgtsandman
12,380
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Makes sense to me. Not to mention the floor in the bed would be so stinking tiny. I imagine there would have to be some over hang aft to make up for that and counter balance the over hang over the cab. But we get back to the axle location....
I'll have to reread the manual. I don't remember it specifying a particular cab configuration. It may have been a blanket recommendation not to install a slide in on any model but I may be remembering things incorrectly as well.
EDIT: I can't find it, though I know I've seen it before. I'll have to do some more digging.
Junk Collector
4,702
Rapid City SD
Speaking of...
Saw this parked at the grocery store up the street a few months ago. I think it had Switzerland plates on it. Super cool rig!
53736
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Being a longtime RV'er, and following our stuff compared to the European made products, their's are years ahead of our RV's.
Almost all their products use lightweight materials, and composites as their vehicles that tow or carry are smaller than ours in general, and their fuel costs are so much higher than ours. They try to keep stuff light.
I would take a guess that the slide in pictured weighs 500-750 lbs less than the equivalent made here. Our stuff is heavy, lots of wood, clunky interior stuff.
I don't think the Ranger pictured, or our US version would have any problem hauling it.
17,488
SW Iowa
My Skamper (wood frame, aluminum skin I think) is about 800lbs dry. Its a popup but I don't see that hardside being over twice as heavy unless the frame is oak with stone floor with granite countertops or something weird like that.
But I can feel mine, without a rear sway bar (which a '19 Ranger does not have from the factory) crosswinds are sketchy. Turning is best described as "different" but you get used to that. I really can not wait to see how adding a rear sway bar changed it, it is night and day different driving the empty truck.
The FWC's like the one I have shown in the back of the newer Ranger are much lighter and stronger with an aluminum frame, I don't know what they run for weight but they are lighter than mine. They are also kind of neat in that you can order a stripped shell and built it however you want. If I was to get a new one... it would be a Four Wheel Camper.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
Your little Skamper is a simple base type pop-up. I was referring to the fully equipped slid-in from Europe that was pictured. It appears to be fully loaded, but from what I can see from the video, looks like its made from a fiberglass shell, which is very simple to line with insulation and an inner shell.
Stuff made here still uses construction from the 60's and 70's with framing, studs, bracing, ect.
I've seen some European rv's at shows, and it puts our products to shame, both in materials used and construction quality. I wish their products were as available as their cars are...it would put many of our rv manufacturers on notice.
Junk Collector
4,702
Rapid City SD
I took a tour of the FWC "dealership" in Colorado - it's actually more of a small shop where they assemble the interior based on what you order... pretty cool... they are a premium product, very expensive. I think the stripped down shell was around $18,000. Construction seemed to be a step above any other RV I have seen. There is definitely more attention to detail but the materials and interior fittings are very similar.
I wish RV builders would have some incentive to produce a better product too. Instead it seems like every new RV I've been in lately has some really glaring defects - doors crooked, screws and nails visible everywhere in the trim and cabinets, holes drilled through walls and not covered up, etc. They have not changed much at all since the early 70's. I've had a few campers and an RV from before that era - they look a little dated by today's standards but the build quality was well above most new RVs today. Even my '73 Mitchell slide in camper is built pretty solid.
racsan
4,317
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Growing up we had a full-size slide in camper, was grandpa’s originally. He had it in a 67 1/2 ton chevy and dad had it in a 74 3/4 ton ford. I don’t recall what it weighed but it was plenty heavy, the brand name if I recall was penguin. Took several trips to florida in it. Back then camping was pretty cheap. Then again, wasnt everything?
JohnnyO
Moderator Emeritus
2,812
Pittsburgh, PA
2.3 EcoBoost
1.5"
Capri Camper used to made a mid-size slide-in but I don't see the one with the cab overhang on their website any more. They have one where they bed is crosswise, it's not real big but I'd be okay with it. Travellight RV makes a mid-size slide-in. I would get one (if I had spare money) for a new Ranger but I'd put airbags on the rear. They're available. Any racetrack or campground I've been to had a bathhouse so I could get by without a shower. Generally I think a trailer is the more practical way to go.
Kirby N.
March Truck of The Month
