Ranger boggs down when first started
Matthewhatt24
Chesapeake city
my truck has a 4.0 its a 94 and it bogs down when I first start it then picks back up and runs fins drives fine idles fine everything is fine but that initial bog down is really weird and sometimes it dies I just changed my tps, crank sensor and fuel filter then it started doing this is it a fuel pump? ICA valve vacuum leak?
5,776
Clean the MAF sensor, once a year, easy to do
Change the ECT(engine coolant temp) sensor, its by the thermostat housing on lower intake manifold
There are two similar devices next to each other
ECT sender, 12volt, red/white wire, ONLY used for dash board temp gauge
ECT sensor, 5volt, 2 wires, ONLY used by engine computer(PCM)
The ECT sensor is used by the computer to set Choke mode, all gasoline engines need to be choked when cold, if this sensor is reporting a warmer or colder temp than actual the engine will bog and stall until it warms up
You can test the sensor, just Google: Test Ford ECT sensor
But in my experience its just better to replace it on speculation, but have a look at its connector first, for signs of corrosion, clean it
Eddo Rogue
1,621
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Yea they'll do that...just give it a little blip of the throttle soon as it fires up. They like that.
