davargo
- Oct 1, 2011
- 0
- Ford
- Engine Size
- 3.0L
A few weeks ago my CEL came on, showing a misfire on cylinder 3. The truck still drives alright, but there is noticeable shaking at idle and at about 1700 rpm. My mileage has also dropped off pretty suddenly.
I switched plug wires, got new plugs, made sure spark was getting to the plugs, and tested the resistance of each injector. All checked out fine, and I still had a misfire. I did a compression test today and measured the following pressures:
1: 140 psi
2: 140 psi
3: 95 psi
4: 120 psi
5: 145 psi
6: 100 psi
Cylinder three is the worst, but 4 and 6 are also noticeable lower than the others. As far as I can tell this is a valve/ring problem, but is it worth the cost of a teardown to fix this on three cylinders? I have 123k miles on it, and can't afford to buy something else right now. How much would it typically cost to have a shop take this apart and fix whatever may be causing the misfire?
I would just let it go, but the mileage is getting worse all the time and cold weather is setting in...
1: 140 psi
2: 140 psi
3: 95 psi
4: 120 psi
5: 145 psi
6: 100 psi
