Random no start
brownmule
Bilixi
Ford ranger
I am wondering how to test my PCM for intermittent function. Sometimes no cel on key on, starter functions no fuel no start. Remove battery cable wait then cel indicator with key on will start, sometimes cel off won't start. How often does the PCM intermittently fail? Is this a Common problem? Troubleshooting advice ?? 96 ranger 4.0 auto
Is there a transmission switch that would affect fuel pump circuit?
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
15,312
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That kinda sounds more like an intermittent ignition switch or EEC Relay.
I'd probably be looking at those connections first.
Uncle Gump
Boomers gotta Boom
15,312
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Next time it happens... listen for the EEC Relay to click as soon as you key ON.
brownmule
Bilixi
Ford ranger
Ok thanks, will do. Suns coming up.
brownmule
Bilixi
Ford ranger
Trying to l😬cate the EEC relay. Google said passenger side kick ? Is it near inertia switch?
Uncle Gump
Boomers gotta Boom
15,312
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Let's back up...
This is your 96?
I don't have schematics for this one... but if it has and underhoad fuse block... it's in there. Should be a road map on the cover.
Your first question was how to test your ECM. Well... connect a scan tool and ensure the ECM communicates with the tool.
brownmule
Bilixi
Ford ranger
Yes. The cover has no labels but numbers. I saw a diagram theat identified the relays and one had to do with PCM I think. I'll look again Hooked up scan tool. Initially wouldn't recognize , but later did.
brownmule
Bilixi
Ford ranger
Ac/PCM power/fuel relays. Intermittent problem and my daughter drives it to high school and work
Uncle Gump
Boomers gotta Boom
15,312
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
In my experience... if a ECM fails... it's done and doesn't work intermittently. Sure... there are always exceptions
Intermittent are hard to locate... but most times are attributed to poor connections.
brownmule
Bilixi
Ford ranger
Been running. The information has been valuable. I've gained a better chance at diagnosis. Thank you Sir$
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
