Rain Leak Door Seal
Bronc3
ASE Certified Tech
23
Zero Gulch, Floriduh
Supercab FX4
3"
Our 2001 extended cab has a minor rain leak issue at the top of both front doors when we get a monsoon. I searched for weather stripping replacements, but the results were more confusing than anything else. Can anyone possibly point me in the right direction? Weather strip shouldn't be very confusing.
franklin2
762
Virginia
If you want to try something, take some insulated copper hookup wire and cut a piece and stuff it behind the weatherstripping. It will bulge it out enough to stop most leaks if that is your problem. Leaks are hard to find sometimes.
BlackBII
Ranger Custom
798
UT
Rockauto.com will have new weatherstripping for your truck
Shadowrider6661
D RANGED
ASE Certified Tech
126
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Doesn't LMC carry weatherstripping ? Not sure of the years but, it might be worth looking.
Bronc3
ASE Certified Tech
23
Supercab FX4
3"
Thanks all, the leaks are definitely the door weatherstripping, both front doors. The rain was really heavy, did it while driving.
