Radius arm and axle pivot bushings
87RangerXLTct
5
Just finished replacing the radius arm bushings and axle pivot bushings on my 1987 ranger 4x4.
I torqued the radius arm bushing nut while the truck was jacked up, my service manual didn't specify on whether to torque it with wheels on the ground. Did I do that wrong?
Also had no way of flaring the axle pivot bushings on the backside. I tried to peen the lip over with a punch, but that wasn't working out well. Ended up making a few shitty tacks with my welder on the back hopefully they won't move?
scotts90ranger
4,359
Dayton Oregon
2.3 Turbo
I have never changed pivot bushings, but radius arm bushings I know...
For the radius arms it doesn't matter, the nut is a lock nut and everything is tightened until it's metal on metal and stops so as long as you felt it stop and snugged it down you're good to go...
Junk Collector
Truck of Month
4,792
Rapid City SD
I hand tighten the radius arm nuts till they're just past snug... I think the torque spec is like 90ft/lbs or something like that... just past snug. In the air or on the ground doesn't matter.
I wouldn't worry about the lip on the pivot bushings. I just drive them in and call it good. They're sandwiched between the two tabs on the pivot brackets... they won't go anywhere.
87RangerXLTct
5
Thanks for the help guys!
