Brain75
- Aug 8, 2024
- 280
- Colorado
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 2WD
So I have enough electrical knowledge to be less than dangerous.... meaning I learned from a licensed journeyman, have rewired 3 or 4 houses, put a complete basement in from scratch - passing all code and inspection, etc.
Someone with more familiarity on Ford radios explain why Walmart says this kit is NOT compatible with a 1990 Ranger...
Looking very closely at the pinout of the 7 pin, it obviously is missing several pins, but by pulling up the schematic here on TRS I see it is redundant ground (2&7 - so missing one ground), and redundant illumination (4&5 - so missing one illumination).
All those are non-issues since you are splicing a 7+8 connector (ford factory) to a ISO (every radio aftermarket now), and can just marry redundant together in the splice anyhow.
a Metra 70-1770 lists for like $15 everywhere, and then the ISO is another $15.... this has both in it for ~1/3 the cost ($11 instead of $30).
Am I just being blind to some other issue or is there an actual reason why it wont work with ANY Ford that has 7+8 connector including the all the 2nd gen Rangers.
metra's own website disavows any knowledge of a part number WM-FD1 and points you to the $30 solution.
Metra does have an install sheet for a "FD1" but that is the steering wheel control and software interface module that is way out in left field.
Metra Online | Parts | Metra Auto Parts Online Warehouse
Metra Electronics, the Installer’s Choice as the leading manufacturer of car stereo dash kits for 65 years.
www.metraonline.com
