Radiator fan, and clutch
6 Round Bales
Wisconsin
hello i have a 1987 ford ranger i'm swapping 5.0 and t5 into, it was originally a 2.3 t5 truck, but it had no power so i sold the motor and trans to a friend, and need to know how can i use an aftermarket radiator fan to turn on when the engine needs it, or would it just make more sense to get a switch or make it run 24/7 when truck is on? also if someone knows while reading this, is there a good aftermarket solution to make it a cable not a hydro clutch, or would it be easier to make a bracket, new master, and exterior slave to make it work?
8,370
Good article to read on cooling fan here: https://www.therangerstation.com/tech_library/volvo_electric_fan.shtml
Article is found here, bookmark this page: https://www.therangerstation.com/tech_library/index.shtml
Look in Cool and Heating section for more e-fan conversions
Also check out the conversion section for V8 stuff
Cable clutch would be a harder conversion, you would need to setup a bracket in the engine bay that pulled a cable back when you pushed the clutch pedal down, so a pivot arm with one end connected to pedals push rod and the other end for the cable end, and you would need enough leverage and movement for the clutch fork
And yes you would need an external clutch fork
Normal cable clutch setup looks like this: https://lh3.googleusercontent.com/proxy/IDcPcAx1Kdq0tSZwgUbSCfkHFi2lub9Won3oUGqPU7AfJ83urL3mG9clvMwGhwQzNaaZ949EOG4kuS1oIso50qmzxCp1O2okA5WJ6gF5KvRak27FdQ
Ranger pedal doesn't have the lever on top and not sure there is enough room to add one
6 Round Bales
Wisconsin
ok thanks, ill look into it, and ill look into both of them, and read some more threads on how to make a hydraulic clutch work with universal, and other parts.
