This truck was purchased from a good friend that used it for many years as a desert prerunner down in Mexico to aid several different race teams. It had been sitting for a while and was happy to give it a new life as a rock crawler.
1989 Ranger
1992 Mustang H.O 5.0 V8 Swap (CA Smog Legal)
AOD Automatic
Manual Shift 1350 Transfer Case
Front axle:
-Custom MitchMade Inc. 3.5" housing with plate truss and AR500 steel bash plate utilizing 02 F-350 D60 Inner C's and knuckles.
-Knuckles have Artech high steer kit welded on and use factory F-350 brakes and unit bearings that have been machines to fit 35 spline outer shafts with conversion Warn locking hubs
-Axles are chromoly 35 spline with 1480 joints
-3rd member is a Gearworks load bolt High Pinion case and pinion support with 10" REM polished 5.83s and Eaton TrueTrac built by Axle Pros
Front Suspension:
-Custom 3 link designed by MithMade Inc.
-Links are 2" .250" wall tubing with 1-1/4" heim joints
-Panhard and steering linkage is 1.5" .250" tubing with 7/8 heims.
-Currently uses factory coil buckets with 5.5" "Crawler Springs" From Wild Horses for an Early Bronco
Rear Axle:
-Custom MitchMade 3.5" trussed housing with AR500 bash plate utilizing Trail Gear unit bearing pockets.
-Hubs are 02 F-350 unit bearings machined for 35 spline and use Trail Gear drive slugs
-Uses F-350 Rear Brakes
-3rd member is a Strange 3.25 case and pinion support with 35 spline Detroit locker and 5.83s built by Axle Pros
Rear Suspension:
-Deaver 64" Leaf springs with custom mounts and shackles
-2.5" King double bypass shocks with custom bed cage
Body:
-Custom front and rear tubular bumpers
-Fiberglass 4" wide front and rear fenders
-LED Rock lights, bumper and hood lights
