R2.8 Conversion Coming Soon!
6gun
11
Calhoun,GA
Solid Axle Swap 4x4
39X12.50R17
I'm not afraid of dying, not living terrifies me!
Well, I took the plunge after much soul searching and place my order for an R2.8 Engine kit and bellhousing to replace the 4.0 in my '99 that gave up the ghost! Planning on R2.8/AOD(w/4R70W guts) and a 203/1356 doubler so that I will retain electric shift 4X4 and have a lever for the doubler. This may be changed to a 203/205 combo. After doing the math this just made much more sense than the 5.0 conversion for me.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
615
Central Indiana
Cool! I've seen a few R2.8 swaps at shows and things but haven't actually followed a build with one.
Ranger850
Doesn't get Sarcasm . . .
4,658
Tallahassee Florida
Stock 2"
Stock
What does an R2.8 come from and what exactly is it? sorry for the dumb question.
alwaysFlOoReD
5,029
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Ha! I knew if I waited long enough someone else would ask.....lol...
Don't feel bad, I need to know too.
fastpakr
2,789
Roanoke, VA
Cummins I-4 crate diesel engine. I had to look it up. :)
stmitch
MTOTM Winner
615
Central Indiana
The R2.8 is a fairly new, 4 cylinder crate engine from Cummins:
Ranger850
4,658
Tallahassee Florida
Stock 2"
Stock
6gun
11
Calhoun,GA
Solid Axle Swap 4x4
39X12.50R17
I haven't been able to find any Ford based swaps yet only Toyota, Jeep and a few odd others. The 2.8 is used in F250s overseas, as well as a butt-load of Chinese trucks. It is only sold here as a crate motor right now. Easy to squeeze out 200HP/325-350ftlb so I'm figuring it will move me around as well as any basic V8 swap and should, theoretically turn in 20MPG or better. Although with it being a Cummins I will be required to say I'm getting 237MPG towing 75K pounds uphill at 95MPH. Roll Coal Brah! Please forgive me, I'm really looking forward to the clean efficiency of this motor!
Ranger850
4,658
Tallahassee Florida
Stock 2"
Stock
alwaysFlOoReD
5,029
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
6gun
11
Calhoun,GA
Solid Axle Swap 4x4
39X12.50R17
Pulling my hair out talking to transmission builders. Want a transmission for up to 300hp/400ftlb that'll be $2K. Oh, it's for a turbo diesel? that's gonna be $3K at least. ??????
twoll86
U.S. Military - Active
9
caseyville,il
Are there any updates on this?
camace2
Colorado Springs
I'm late to this conversation but diesel engines have a very "pulsey" power output. Aka the power output is sinusoidal with high amplitude torque pulses. Transmissions have to be specifically built for this form of power input. Its like needing an inverter to smooth out the power to charge your laptop from a generator without frying it. A flywheel with some beefy dampening springs helps a lot but there is usually more to it than that.
Secondly, because the torque/power curves look so much different between gas and diesel, the gearing ratios will not necessarily be the same. The transmission tuning will look different too; changing shift patterns to optimize power delivery and fuel economy.
I'm sure you can find someone with anecdotal evidence that will tell you their conversion worked just fine...and that may be the case more often than not. I'm just giving you an engineer's perspective.
bobbywalter
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
BIGGER
sawzall?
Not sure if he has proceeded with swap ..and I missed this initially....
But the aod is one I would not use on a diesel....it direct drives thru the tc hub.
If you want an auto with a 300 hp diesel....start with a 4l80.
At least something with a clutched converter.
Kirby N.
March Truck of The Month
