Mrtin
- Oct 23, 2009
- 0
- Austin, TX
- Ford
- Engine Size
- 2.3L
Hi all. I've got a 1992 2wd R1.
My transmission recently went out. I found a great deal on a used R1 from 1998.
I know that '98 Rangers have a very different speedometer set up that does not go into the tail housing like the old days. I also noticed that the tail housing of the 98 did have a space for the VSS, it just wasn't completely drilled out. I thought this might mean that everything was still the same back there, there just wasn't any way to access it since it wouldn't be needed.
I decided to take the tail housing off my 1992 R1 and put it on the 1998. I thought that in doing so I'd be able to have a speedometer. I just got it all together and no deal. The speedometer isn't moving even slightly.
My question is this: What turns the colored speedometer gear? I figured it was spun by some integral part of the output that would be present in all years. Am I wrong about that? Do the older R1s have a gear in the tail housing that is only for spinning the speedo gear and is not present in models with the speedometer in the diff? In other words, can I make this work or am I out of luck? If indeed the VSS from my 1992 just wont work in my 98 transmission, is there anything else I can do to get a speedometer?
In looking at the shaft on the old transmission I see a hard plastic ring with groves in it that sits around the output shaft. Is that what drives the speedometer gear? I hate to admit it, but I have no recollection of seeing any difference between the two transmissions when I had them side by side with their tails off. If indeed that is the part, and indeed it is not present on the '98, could I swap that over fairly easily? I haven't got the heart for pulling the tail housing this moment, but I'm in a place with state inspection right now and it may by a requirement to have a speedometer.
Thanks everyone.
Thanks everyone.
