quick M5OD swap question
Beef52751
13
Eastern Iowa
Hey, I am sure this has been covered before i but cant seem to find it. I have a FM145/1350/D28 Combo now i am swapping in a M5OD/1354/D35 Combo, my question is: Can i Use my existing 2.9 Clutch for now or do i have to swap in the 4.0 Clutch with the tranny. (the trans. is from a 4.0)
Tranny doesn't care what clutch it has, they all have the same splines.
Beef52751
13
Eastern Iowa
what slave do i use???
4x4junkie
580
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The slave that matches with your master (IOW, one for your year truck, they fit both the Mitsu or the Mazda, as well as with the 2.9 or 4.0 clutch).
Perfect opportunity is right now for the 4.0L clutch upgrade... Not sure why you want to pass that up, the 4.0L clutch is just sssooooooooooo much better, way better pedal feel, not so sensitive, you can actually modulate it much easier (forget the fact it simply grips better).
I did the swap on mine, I can't recommend it enough. Well worth it.
Beef52751
13
Eastern Iowa
im going to, i just want to get the whole setup in and driving so i can test a few things before i spend more money on a clutch
Kirby N.
March Truck of The Month
