Quicc help
OneGoofyGuy
5
Ramhurst, Ga
35x12.50x15
1989 Ford Ranger XLT 4wd swapped to a 4.0l
All I had left to do was bleed my clutch and drive it. But some things come up and I hadn't touched the thing in a week or two. I got me a new battery thinking that was the problem but it's something else. Whenever I go to turn over it just clicks at the solenoid next to the relay box. But what doesn't make sense is a used to crank over just fine.
Much appreciated
Uncle Gump
Token Old Guy
13,428
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would ensure your engine ground is clean and tight.
Any poor connection in the starting system (positive or negative) will result in the dreaded "click"
OneGoofyGuy
5
Ramhurst, Ga
35x12.50x15
Connections are clean both - and +
The solenoid is still clicking.
Still no clue.
I doubt it needs another solenoid.
ericbphoto
Overlander in development
16,526
Wellford, SC
3.0L
6"
What is your battery voltage reading?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
A very sassy volt meter will make short work of your issue. A starter solenoid clicks for two reasons, its broke. Or doesn't have enough voltage.
OneGoofyGuy
5
Ramhurst, Ga
35x12.50x15
I replaced the solenoid still clicks. I'm gonna double check all connections with the starter, battery and such.
OneGoofyGuy
5
Ramhurst, Ga
35x12.50x15
I only have the screwdriver looking volt meter the handle glows.
ericbphoto
16,526
Wellford, SC
3.0L
6"
Test lights are helpful. But sometimes you need real numbers. You can get a meter at Harbor Freight or Northern Tool for less than $10. They aren't great. But usually adequate for simple automotive use. Harbor Freight sometimes has a coupon to get one for free.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
2 wire or one wire starter? May need to move the wire
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
These guys are right, check your connections. Look for anything loose or corroded. Check the connections with a meter maybe.
Worst case rewiring to the starter from the battery is pretty easy, and will make for a pleasant Friday night activity.
Ranger850
Doesn't get Sarcasm . . .
4,680
Tallahassee Florida
Stock 2"
Stock
Quick glance at the TITLE and I thought someone want to ask questions about Quiche
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
REAL MEN EAT OMELETS!
OneGoofyGuy
5
Ramhurst, Ga
35x12.50x15
Actually I've never heard of that. I spelled it as quicc like thicc lol
Ranger850
4,680
Tallahassee Florida
Stock 2"
Stock
FYI spelling things with a "cc" instead of "ck" like thicc and quicc, is Gang culture. "Crips" don't use "ck" because it stands for "Crip Killer" and use "cc" instead. Unless you are "Crip" then never mind, because you already know this.
OneGoofyGuy
5
Ramhurst, Ga
35x12.50x15
I got a meter and the wire coming from the starter reads 3.82 volts when the ignition is off. When the ignition is on the wire coming from the starter to the solenoid is -0.45 volts
The wire coming from the solenoid to the battery is -0.07 when the ignition is on
