rangeron33s
- Aug 16, 2013
- 0
- missouri
- Ford
- Engine Size
- 2.9
I have pulled the bed on both the rangers I've owned. The first one was just to put a new muffler on (it really helps for getting that weld on rite) only snapped the front 2 bolts so I put the bed back on without worrying about it. This one is an 88 though. Had to replace the sending unit and snapped every single bolt and had to grind off the clips and studs. Ended up rigging up a quick release. Took six bolts and drilled a hole through the end sideways and dropped them through the holes and then used cotter pins with rubber and steel washers so the bed would be snug without any wobble
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
