Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
- Aug 2, 2000
- 8,708
- Nocona, Texas
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 / 2.3 Ecoboost
- 2WD / 4WD
- 4WD
- Total Lift
- 6-inches
- Tire Size
- 33x12.50x15
Not to sound paranoid and leaning on the side of caution.....
Although this is becoming a huge problem in other countries (global death toll has passed 3,000), as of 03/02/2020 the United States has had 6-deaths and has been reported in 11-states.
Do your part to help prevent the spread:
1) Wash your hands with soap and water to minimize your infection risk. The best way to prevent coronavirus is to wash your hands as often as possible. Wet your hands with warm water, then apply a mild soap. Work the soap into a lather for 20-30 seconds, then rinse your hands clean under warm running water.
5) Disinfect high-touch surfaces daily using a product that kills viruses. Unfortunately, coronavirus can linger on surfaces, such as doorknobs, countertops, and faucets. Use a spray disinfectant or bleach wipes to clean these surfaces daily. Make sure the surface stays wet for about 10 minutes so it effectively kills the virus. This limits the risk of the virus lingering on the surfaces and potentially causing an infection.
- Always wash your hands before you eat or drink anything. However, it’s also best to wash your hands anytime you’re out in public or after you’re around someone you suspect may be sick.
- If you can't wash your hands, use a hand sanitizer that contains 60%+ alcohol.
- If you need to touch your face, wash your hands first so you’re less likely to infect yourself.
- If it’s appropriate, ask the person to stay away from you. You could say, “I noticed you were coughing. I hope you feel better soon, but please keep your distance so I don’t get sick.”
- If you know someone has been around sick people, it’s a good idea to distance yourself from them, too.
- In your home, disinfect your front doorknob, kitchen counters, bathroom counters, and faucets.
- At work, clean surfaces that people tend to touch, such as doorknobs, stair railings, tables, and surface counters.
- You can also make disinfectant by mixing 1 cup (240 ml) of bleach with 1 gallon (3.8 L) of warm water.
