Project punisher
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Well ive done alot and took very few photos but i thought i might share the progress.
First off i installed a 4" spindle lift then a 2 coil spring lift to total 6"
Sent from outer space.
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Image spam!!!
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
About ready to begin the wire harness swap
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Note to self. Aftermarket valve covers cause clearance issues...
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Well since ive been the only one posting on this, does anyone know if the master cylinder on the explorer need to be swaped over for the 8.8 disc brakes or does both the mast cyld and booster need to be swaped
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Nope, both use the same master cylinder. Nice build. Sub'd
SVT
win
12
No need to muck around with the booster or master cylinder. The Ranger bits should work fine with the Expo 8.8 and its disks.
Only problem I had was getting the parking brakes to work correctly. Had to shorten the "mid" cable by 2". Expo rear cables, modded the mid cable and used the Ranger parking brake pedal assembly.
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Thats great to know, already swaped it over since i had to swap the brake pedals. Does anyone know anything about the motor mount plates. I know the passenger side has a offset but is it an up ir down offest
win
12
Its an upward offset that lowers that side of the engine the thickness of the plate.
When installed, the bottom of the block's bosses are level with the bottom of the plate.
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Hmm, ive read something special about a spacer needing to be removed on the passenger side.
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Thanks for the info
Jbrown1238
6
Largo, Fl
306
None
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
On the stock mastercylinder, does anyone know the purpose of the adapter that screws in the rear port???
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Kirby N.
March Truck of The Month
