Project for maybe 3 years down the road
Paisano
133
Phoenix, AZ
Ford Ranger XLT
92' Ford Ranger Supercab with 2.9 V6................with 8.8 rear axle assembly for 99-2008 Ford Ranger.
Friends,
I have new drum brakes with my recently installed rear axle assembly. I want to let these drum brakes run their life cycle, and then be done with drums for good. I don't want to take up a lot of anyone's time.
This is something I would like to do maybe 3 years down the road. When that time comes, can I convert to rear disc brakes?
Would it generally go like this...............pull axle shafts...........bolt on disc brake backing plates/install disc brakes.........install parking brake system that does not use a drum.......and replace with compatible brake lines and master cylinder if needed
Like I said, no need to take up a lot of anyone's time right now. But is this doable?
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Paisano
133
Phoenix, AZ
Ford Ranger XLT
Will do Ranger850.
I got plenty of time to look into this to see if this will be an option.
sgtsandman
Aircraft Fuel Tank Diver
12,636
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
There is a couple options out there to do a disc conversion. I believe they are all covered in the technical section. I think the Mustang conversion is the one that uses your existing axle to do the conversion but I’m not completely sure on that.
Paisano
133
Phoenix, AZ
Ford Ranger XLT
Yeah Sandman, I also heard that about the Mustang backing plate possibly crossing over.
I saw this rear disc brake setup that uses a smaller caliper mounted next to the primary caliper. The small caliper is the parking brake. No parking brake drum. Just a separate emergency brake system on the same rotor.
VERY expensive
scotts90ranger
4,366
Dayton Oregon
2.3 Turbo
That setup Ranger850 linked to would be the simplest, especially if you could find junkyard parts, don't know what the kit would cost...
Paisano
133
Phoenix, AZ
Ford Ranger XLT
Yep. Ranger850's procedure is the one I read about this weekend. Now I have to ask myself if it will be expensive and will there be good parts availability.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
:yahoo:
I ...
I think I just "contributed".
sgtsandman
12,636
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
:yahoo:
I ...
You better play the lottery because you won't have a better chance than now. Oh, never mind you blew your chance with that post.
Uncle Gump
Token Old Guy
13,455
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Look at LugNut4x4 for their Eldorado calipers and kits. No drum parking brake and was recommended by Bobby Walter
Paisano
133
Phoenix, AZ
Ford Ranger XLT
I'll check it out Gump
Roert42
4,959
Kintersville, PA
Ranger XLT
4.0 SOHC
The mustangs brakes from that tech article don’t use drum parking brakes. They have a ratcheting cylinder in the rear caliper for the parking brake.
I would think anything mustang related is going to be the easiest to get cheap parts for since they are so common.
Paisano
133
Phoenix, AZ
Ford Ranger XLT
Cool. Someone earlier said to make sure my axle shafts are 28 spline. They are.
