I replaced the hose, check valve and grommet for the booster, and while it was running I checked for leaks by closing the hose off. I also used brakekleen at all hose locations and intake manifold gaskets as well. The brakes are all new, right down to the springs for the shoes. When I did attempt to drive it up the street the brakes worked properly. I went down and talked with the rebuilder and he said he'd call an old Ford mechanic he knew and see if he would come by to take a look at it for me. No call back yet but I am hoping he'll be able to pick out something that I'm missing. I have advanced the timing as far as I can and still have it start; but vacuum only went to 14". He also said the cam/crank timing could be double checked so I think I will tear things back apart and make certain it's correct. I do have a lot of faith in the rebuilder for both his experience and knowledge as well as his ethics. He's been able to answer any questions I've had for him; he even gave me a technical bulletin from Ford concerning intake manifold problems on this engine. All mating surfaces including the exhaust and intake manifolds were also checked and sanded for flatness. For today, it is back to the vacuum routing on the old 454 one ton dually! Thanks guys! This one will get solved!!!
