Problem with 2002 ranger transmission 5r44e (I think?)
Ohhnulix
4
Dade city
Ford ranger
I’m a little new to vehicles. But I recently bought a 2002 ranger edge 3.0 with some transmission problems, I’ve been messing with it because the guy said the transmission had just been rebuilt but was still not working right so he sold it. The truck acts like it doesn’t want to grab onto gears, reverse and drive do pretty much nothing until the truck rolls for a bit. But if I manually throw it into 2nd or 1st gear is runs like a champ. Any ideas as to what could cause this?
Rock Auto 5% Discount Code: 81874766E40C6A 5th, 2022
Dirtman
13,294
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Start simple... check the fluid.
Warm the truck up (let it run at least 15 minutes) put it in park with the engine still running and check the fluid level. Also check color (should be bright red). It should not be dull, brown, black, foamy, or smell burnt.
Is the "overdrive off" light or check engine light on or flashing? If so take the truck to autozone or advance and have them pull the codes.
Unfortunately saying the transmission was "rebuilt" means absolutely nothing. The guy you bought it from could have simply lied. Or the place that rebuilt did a poor job, or didn't service the valve body, or worn hard parts.
Not moving like that usually indicates a pressure problem which could be alot of things. Bad pump, blown valve body seal, bad solenoids. The list goes on...
Ohhnulix
4
Dade city
Ford ranger
Is the "overdrive off" light or check engine light on or flashing? If so take the truck to autozon or advance and have them pull the codes.
already checked the fluid, looks brand new.
when I drove the truck to my house when I first got it the O/D OFF light was flashing, didn’t know at the time that it was a check transmission light, and I can’t seem to get it to come back on so I can scan the codes. The major thing that confuses me is it drives perfectly fine if you manually put it into a gear, it just doesn’t want to grab into gear by itself
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Really common issue when OD sprag (one way clutch) has failed.
Brad
Ohhnulix
4
Dade city
Ford ranger
Brad
Hm, a quick google search found a few other posts with the same issue, is this someone that can be fixed easily? Or would it be better just to throw a new tranny in
Transman304
43
Morgantown WV
Chrysler PT
2.4
Not a terribly hard repair if you have some wrenching experience. Transmission has to come out and pump removed plus some other parts. Couple of gaskets and seal will be needed with the new sprag also. Also the race that sprag runs on will probably be damage. You will need OD planet if it is.
Brad
