- Aug 17, 2016
- 1
- Seattle, WA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 92' 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- 7"
- Tire Size
- 33x12.5
So this is kind of a long story but basically I bought a 1987 Ranger a little over a month ago that the previous owner did a 1991 4.0 swap on. I had been without a reliable vehicle for over a year due to my terrible luck with vehicles breaking down and was stoked because I finally thought I got a reliable one (haha). It ran amazingly at first until three weeks ago when it died all of a sudden on the freeway, and I had to get it towed home. It had spark, compression, fuel pressure, and would crank, it just wouldn't start. After checking everything I could think of and giving up, I let my mechanic friend look at it. He figured out the injectors weren't opening, but couldn't figure out why and he also gave up. I finally took it to a supposedly really good shop, they spent a week and a half checking everything, and got so frustrated with it that they almost actually gave it back to me. They said their only guess was that it needed a new computer, which I bought, and that didn't work. Then they finally figured out that the "PIP signal to ECU is grounded with the key off."
They ran a wire outside of this harness to bypass this problem, and finally got the truck to start. But it sounds terrible, dies when it gets any gas, and is un-drivable. The problem is, the previous owner used everything from the 1991 except the wiring harness that goes from the engine to the computer and the ignition control module and all that. For some reason this is still the 1987 harness with a mess of splicing and mismatched wires. Because of this, the 1991 computer is having a hard time reading incoming info from sensors, and it's impossible to pull codes from. It doesn't even have a mass airflow sensor on it and it's basically just running in the failsafe mode.
Anyways, sorry for the novel but does anyone out there have any advice on what to do next? The mechanics said that if I can source a 1991 4.0 engine to computer harness, an MAF sensor, and the intake that can accept the sensor, it will officially run like a complete 91 4.0. I'm pretty lost on what years/models are compatible with this, so I figured you guys might have an idea or where the heck to find them. Thank you so much!
