Well.....
09fx4guy, glad to hear from you. You are correct, phase timing is everything. Some music like from Edgar Winter & Heart both contain well presented and very low sonic waves. Having any amount of inversion or phase cancellation at the soundstage will only kill the intended effect and the muddy vibrations ensue. That is why I believe in only one single source of frequencies from one source.
I want to keep things as stock as possible, well perhaps a little stealthy. Having a stock sub wolfer would be fine.
My old '83 had some serious sound system components. It was a 6 channel. 25x25x100w. 2 amps, one 4 ch & one for bass running 2 x 10" wolfers. I loved the 40 watt ribbon mid/tweeters running all the way open down to 300hz, but they never saw more than a few watts with an op amp active type 12db/octive crossover. Rabbit hole coming, however if I could replace the 4 speakers, the front with that ribbon.....
Link-
https://www.parts-express.com/GRS-PT6825-8-8-Planar-Mid-Tweeter-8-Ohm-272-126?quantity=1
Then a decent wolfer (does Bose make something for a small truck?) then perhaps I could get away with a bi-amp setup using the rear door speakers in mid/upper bass to lower mid range duty and the ribbon planars up front. Alpine 8" series R with a class D amp, 200w would be fine. $$$
The head unit? Well, still dwelling on using my old Yamaha stuff from the middle 80s! But I believe my navigator (wifey) would like something with a touchscreen which opens a whole other $$ account. Crutchfield & Bestbuy see me coming...
I never saw a Pioneer logo.
Glad to have you all commenting. - Doug
