Preemptive Water Pump Replacement
alteredwalter
Edmonton, Alberta
Hi folks,
I am in the middle of swapping out the heads on my 2005 Ranger (120,000 miles) and I am wondering if it would be a good idea to change out the water pump while I have good access. The fan and rad are off and all of the hoses and brackets are out of the way. It looks like it would be a pain to change later on once every thing is back together.
To this point there are no coolant leaks I can see and the fluid was very clean. The pump spins fine and the bearing seems tight not sloppy. As far as I know the pump is fine, but it seems like others are having issues around the 100-120K mark so I thought it might be a good idea to just go ahead and replace it. But since some of the bolts go through the timing cover and I don't want to compromise the TC seal I wanted to get some opinions from more experienced members and see if:
  1. It is a good idea to replace working parts at regular intervals as a preventative measure
  2. Are there any tips or things I should look out for if I do go ahead.
In addition any recommendations for aftermarket water pumps would be welcome. The AC Delco gold ones are a bit cheaper than the Motorcraft but not sure it is worth the $25 savings.
Thanks in advance
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
Eddo Rogue
484
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
If you do, replace with it with good one, many parts are junk aftermarket these days, ranger waterpumps is one of them....ac compressors and alternators as well.
DILLARD000
136
Earth
2001 Job2
Ford ExST
V6~4.0L~SOHC
Since you got easy access & 100kMiles on the pump, I would swap it out & cleanup+keep old pump as a backup. I know they say the bearings are sealed, but I've always soaked both side of bearing with penetrating oil for a couple of hours before putting a pump on.
Blmpkn
904
Southern maine
Ford ranger
2.3
I'd replace it. Easier and cheaper to do it now than it will be down the road.
gw33gp
177
Costa Mesa, CA
4.0 SOHC
33"
My water pump has 263K miles on it and is the original from the factory. I was going to replace it when I did the timing chain system rebuild at 255K, but the Ford dealer sent me the wrong pump. They did exchange it for the right one, but I had the engine back together and in the engine bay. Someday when I get around to it with some other work needed, I will install it. The water pump was still in excellent condition at 255K. I think at 120K yours should have many miles left on it if you have taken good care of cooling system.
However, you never know when something like that could fail. Then again, you could replace it and still have a failure. My brother, who is a professional mechanic, tells his customers; don't replace original equipment if it is still working. He has found that many replacement parts tend to not last as long as original equipment.
It is really your call on this. I always use parts from a Ford dealer (usually online orders after finding the least expensive) or Motorcraft from a place like Rock Auto.
3,497
On the 3.0L Vulcan a common issue was the timing cover gasket leaking coolant, there are two coolant passages, and either can leak
This is a pic of the block with the two coolant passages: https://i.ytimg.com/vi/w68Ld8eKp7k/maxresdefault.jpg
And a pic of the front cover, with a sentiment about its design:
Water pump bolts to the front cover
Reason I bring this up is that water pump replacement is fine, when its weep hole or gasket is leaking or there is an overheating issue you think is water pump related
But if you are just going to replace a 3.0l Vulcan water pump on speculation or general maintenance, I would also do the front cover gasket...........or don't bother
It could last the life of the vehicle, water pump or front gasket, or it may not
alteredwalter
Edmonton, Alberta
Thanks everyone. I appreciate all of your input.
I had pretty much talked myself into swapping it out but the last 2 posts have me thinking I am best to leave the current pump in place and make peace with the fact I will have to get back in there down the road. The truck (which I bought last year and promptly had to garage due to the head issue) has clearly been well cared for based on how clean everything is inside. And with my luck I will no doubt end up having RonD's timing cover issue down the road so I will deal with it then.
Thanks again!
