Powerdome hood swap fitment issue
JoshT
1,682
Macon/Fort Valley, GA
I'm putting an 01-03 "Edge" powerdome hood on my 99 Ranger XLT and keeping the stock XLT grill and headlights for now. I've seen enough photos of it to know that it works and can be done. The hood to grill lines aren't perfect but it works and doesn't look terrible. At this point I have the hood bolted to the hinges but I can't get it to latch properly. I have got the hood latch adjusted all the way up and the striker spaced down nearly a half inch with washers to get it to latch at all and it feels like it still needs more. I've never heard of this being needed for this swap, and all the pictures I've seen look like they still ahve a better hood to grill gap than I've managed. .
Any of y'all run into this before? How did you correct it? Is there an adjustment I'm missing?
I'm almost wondering if there is a way to adjust the grill and/or header panel down so I can atleast remove the spacers. If I did that though the the hood wouldn't line up with the fenders, it might be sitting too low. Just kind of at a loss on how to get this fitting and latching right.
lil_Blue_Ford
6,100
Butler, PA, USSA
4.9L
Hmm, I didn’t realize any of this was a potential problem… I was intending on swapping a powerdome hood on my green 00. I got a fiberglass one awhile back and had thought about punching holes in the cowl side to make it sort of like a cowl induction.
JoshT
1,682
I don't think it normally is. I think there is either a problem with my hood, my latch, or adjustments of body panels.
Hood: Its fiberglass, if it bends that much it's breaking. Besides the curve of the hood matches the curve of the fenders. I also swapped the striker from the stock hood to see if that made a difference, it didn't.
Latch: Maybe, I haven't got another here to compare it to. Was working just fine with orignal hood. I've currently got it adjusted up as much as possible. I could modify the latch to raise it higher, but that whouldn't be necessary and I Want ot use it as a last resort.
Body panels: I don't know what was done on the front of this truck before I got it. I do know that the PS side fender and grille have never been off in the time I've had the truck. I removed the driver side fender the other day to run some wires behind it. I'm pretty certain that I got it back in the same spot, but it's not preventing the hood from doing like its supposed to. It's almost like the header panel, grill headlights, etc need to move down relative to the core support, but I don't see how that's going to happen and still line up with the fenders.
lil_Blue_Ford
6,100
Butler, PA, USSA
4.9L
Hope someone has some more input on this, I was of the understanding that the problem you’re experiencing isn’t an issue with this change and the only possible issue was the fit against the headlights and grill, which would be easy enough for me to do at this point and is a thought I’ve been kicking around
superj
2,571
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
Powerbulge hood?
What is that? It ended in 03 though? Dang since mine is an 04.
lil_Blue_Ford
6,100
Butler, PA, USSA
4.9L
Powerbulge hood?
It was like a mini Superduty hood, I’ve seen them on some trucks newer than 03, but they were aluminum instead of fiberglass. I got a fiberglass one with a couple repairable cracks awhile back for free. Haven’t found a good deal on another though yet.
cbxer55
767
Midwest City, Oklahoma
We have a couple newer Rangers at work for work trucks. I've looked at the hoods, and to me at least, it seems a new grill would be needed to match the hood. Same with the bumper, the dip in the center looks deeper than the dip on my 98. I've wanted to put a newer bumper on the front, but don't think it would match the grill assembly. Input?
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I was under the impression that doing this swap required pretty much everything.. core support, bumper, ect
cbxer55
767
Don't know about the core support. The newer ones we have at work, pretty much look the same under the hood. Guess I am just going to find a new bumper for a 98 - 00. I want to do a face lift this year, the front end is getting tired. Already have a new grill, just need to get it painted satin black. I ordered it that way, but it fookin came fake chrome. Idiots!
But, I also had to get a new grill / headlight surround for my 04 Lightning. The factory one was cracked as well. Only one I could find is also fake chrome. There is a body shop a half mile away, I'm going to deliver the parts there tomorrow.
JoshT
1,682
The actual powerdome hood was fiberglass and came on 2002-2003 Edge and 4x4 trucks. All 2004+ trucks came with a similar appearing hood, but it was aluminum and didn't have as much rise. Using the 2004+ hood does require using the 2004+ grille and header panel.
I think I gave $100 for mine many years ago, but just now getting around to trying to use it. The grill and header panel might be coming before long, but I can't find one used local right now. Don;t mind buying new, but I've got too many other expenses at the moment to buy all new parts and headlight assemblies right now.
The hood will fit with the 99 grill. Here's one of many examples I found when searching this recently. https://www.ranger-forums.com/exterior-semi-tech-39/edge-hood-99-a-57580/
Putting my stock hood on a truck with the 2002-2003 Edge/4x4 grill will leave a big gap at top of the grill, but it works too.
I have it on good authority (and seen the pictures) that bumper assemblies from 1998-2011 will interchange. I will be putting an 05-07 bumper on mine once I figure out all the parts I need (or find a complete used one) and have the spare cash to put towards it.
Definitely not the core support or bumper. Core supports are the same from 1998-2011, the bumpers I mentioned above. If you want to update the grill to a newer design then you will have to get the matching header panel and head lights.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
645
Central Indiana
My Cobra hood started as a Powerdome. I've never heard of these issues with installing one on a 98-00 nose. It is a heavier hood than the aluminum flat hood. Any chance that's impacting it?
JoshT
1,682
Yes and no.
My dad has a 2002 4x4 with the powerdome stock. I got a chance to look at his truck yesterday, but unfortunately wasn't able to get.mi e.iver there to compare side by side.
Yes, it could definitely have an impact on "popping" the hood. His response.exactly like mine does when the release is pulled. The latch releases, but the hood doesn't pop up like with the aluminum hood. I'm fine with that if it's supposed to be that way.
No, I don't think weight should be causing a difference with the alignment/adjustment. Without having them side by side his latch looks the same as the one on my truck. The striker looks the same as the one that came on the hood I have. His doesn't need or have spacers on the striker, and it seems to close better than mine does. Again didn't have the side by side to compare.
cbxer55
767
I had my 98's hood replaced in 2015. It's a stock look steel hood. Pops up without issue when I pull the hood release. Of course, there are a lot of holes in the hood under that scoop. And two big holes on either side, replaced with plastic vents. So maybe it's just a little lighter.
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
5.0L GT40
The OG fiberglass PowerDome/Edge hood fits a 98-00 I've done it a few times and one of my rangers has one right now. It is a simple bolt on. The gap is tight to the grille, tighter than it is on an Edge, as the edge grille is frameless at the top.
Adjusting the hood-to-hinge bolts, the rubber spin up stoppers, and adjusting the radiator support's catch latch up to max was all that was needed, but it is a tight shut. Although there was no modification to do, the hook on the hood itself should not need to be changed or spaced down at all.
Here is my 2000 with both a 98-00 grille/headerpanel and a 01-03 grill/headerpanel.
Josh B
1,986
Oklahoma
How do you go about lining those up?
I'll be pulling some motors soon and am worried about being able to get them re-aligned
