power windows
black06xlt
i recently converted my 06 to power windows using all stock parts from a 2004 ranger. i like the looks and design of 07-11 switches and interior grab handle better the older trucks. does anyone have wiring information on the 07-11 window switches?
8,369
2004 and 2007 look to be the same just different wire colors
black06xlt
the switches i want to swap to are from a 2009 ranger
8,369
Those are very different, Master is just that, the master, lol.
But on the upside this type of setup would be an easier swap than older style
One 12v wire to each door
Two wires from drivers door to passenger door
Ground wire for Master
Which is similar to older but without external one-touch and relays
black06xlt
is there any information on wiring this to the older set up?
black06xlt
reading wiring diagrams is not my strong suit.
passenger door - brown/yellow
green/orange go to the yellow/violet on the left door
violet/white - 12v power
driver door - blue/gray to the up side of window motor
yellow/violet to the down side of motor
black/blue is ground
what wire is the power on the left door and what is the second wire to go to the passenger side door?
8,369
There is no matching of wires unless you already have power windows
2009 master looks to be self contained
You need a 30amp fuse, hooked to Key on or Key off 12volts, your choice on if you want the windows to work all the time or just when key is on
1 wire from that fuse to Drivers door master
2nd wire from that fuse to Passenger door slave
1 Ground wire from master to drivers side kick panel Ground
2 wires from drivers door thru dash to passenger door slave
If you have older style power windows you won't want to use most of its wiring at master because of "one-touch" module
There should be 2 wires from drivers door to passenger door that you could use, you just have to test/ohm those wires to ID them.
I would ask a friend who can read a diagram for a hand, it is pretty straight forward
Window motors are just 12v DC motors so if you give them 12v on one wire and Ground on the other, the motor turns clockwise, window rolls up
If you reverse the 12v and ground on the motor wires then motor turns counter clockwise, window rolls down
Thats what the push buttons do, they select the direction the motor turns, clockwise(12v/-) or counter clockwise(-/12v)
black06xlt
i think i have it figured out. thanks
