power steering pump
IMenriched
4
NE Iowa John Deere country
02'
2.9 & 5.4
Just some looking for info on changing out my Power steering pump on my 02' f150 4x4 hopefully before snow flies.:icon_thumby:
Anyway, I think/ pretty sure I need 3A674(STP-86-RM) , but I also see that STP-130RM may work too.... so my question is which is right and what is the difference??? Does it matter?
Well and also, how big of a chore is it to change one out? Getting the drive pulley swapped seems to be one of the top hemorrhoids :shok:
SO 3A674 is a base number, and doesn't tell you much of anything aside from "it's a power steering pump".
I am not sure what the exact differences are between the two parts you posted, but the only thing I can remember is that on some years the pump is held by four bolts, other years it's only three. Shouldn't affect fitment if you use one or the other.
Changing a Triton engine's PS pump is not what I would call fun, but it isn't terrible. The worst part is the pulley. The bolts can usually be accessed pretty easily through the wheel well with long extensions.
IMenriched
4
02'
2.9 & 5.4
hey thanks for the reply. I'll look things over more closely before I start and double check the mounts. I was suspicious it wasn't easy....but doable.
IMenriched
4
02'
2.9 & 5.4
sucess
well about a month ago I did get the PS pump swapped out.
The bigger chore was getting the new high pressure hose to start back into the steering gear box. If I had to do it again I probably would remove the fan and the shroud ....just for a bit more room to work.
