DisturbedMXer8
- Dec 7, 2009
- 29
- Anaheim, California
- Ford Ranger XLT
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 2WD
Recently I've been noticing my starter doesn't like to crank my engine when it's hot (i.e. after I have the engine warmed up, and I stop for 10 minutes or so for gas or whatever). One day I filled up and it straight would NOT start back up. It eventually started to crank, and it took 6 or so cycles before it fired up. This truck normally starts the instant I turn the key. Well I noticed while cranking that some smoke was coming from underneath my hood (not steam, smoke), and found this when I popped the hood:
Those are my ground cables. It's (obviously) an aftermarket terminal that I replaced my old one with while I was searching for bad grounds due to my other problem (if you've seen that thread). That's my starter relay ground on the far right, battery to block ground in the middle (big red one), and the little black one goes from there right to my core support. Now, why in the world would my ground wires melt together all the sudden? High current from the starter? Last time I checked that shit's all used up when it hits ground (granted it's disconnected from the batter, but still...).
When I disconnect that negative terminal and measure avail. voltage there (negative post to negative cable terminal) I get about 10 volts, key off engine off. Is this normal? I didn't think there should be any voltage there key off engine off. I'm starting to suspect a short to power on the ground side somewhere, but I've no idea what all to test. Again, with negative cable disconnected, I get about 10 or so volts at the block, core support, cylinder heads, intake manifold, etc... this has to be a short to power, right?
I'm thinking this will not only solve my starting/melting grounds problem, but possibly my other one as well. Can anyone help me out? Is this normal, or or am I shorted somewhere?
