- Feb 15, 2020
- Reaction score
- 6,359
- Location
- Southern maine
- Make / Model
- Ford Bronco
- Engine Type
- 2.3 EcoBoost
- Engine Size
- 2.3
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5"
- Tire Size
- 285/75/18
- My credo
- Its probably better to be self deprecating than self defecating.
Couple weeks ago during the first real cold morning of the year I noticed that my heat doesn't work. Brrr.
Read some stuff from another forum posted by ranger Jesus RonD that helped me partially diagnose why. It's NOT the vacuum valve under the hood, its either the blend door actuator or a plugged core.
NOW, I dont currently know where my mirror on a stick is.. so it's hard for me to see if the blend door actuator is functioning.. BUT both hoses coming through the firewall seem to be roughly the same temperature AND the coolant is about as clean as one could expect.
This leads me to believe its the actuator, but the much higher price tag to have the core replaced coupled with how good my luck is has me preparing for worse case ontario.
Would a vehicle with a plugged core have clean coolant? I would think that it would be gross. I'm gonna hit both hoses through the firewall with my infrared thermometer tomorrow to see exactly what the temperature difference is.
Thoughts? Is a crummy blend door actuator common on rangers? How bout a plugged core? Thanks gang.
