Possibly bad GEM module
Ravenmer
Washington, USA
Mazda B3000
Hi all, brand new here!
I have a 1998 Mazda B3000 that I think the GEM is going bad on from reading the different forum posts from here and elsewhere. The truck's speedometer and the windshield wipers don't work. This has been occurring intermittently pretty much since I got the truck a couple months ago and got worse/ doesn't work since my battery died on me a couple weeks ago. I pulled the GEM and reset it and it worked for one drive and then stopped again. My GEM # is F87B-14B205-EE and the truck is a 4x4, manual transmission, with manual windows and I saw on eBay that the EE is for an auto with power windows. I just pulled all of the fuses associated with the wipers and the GEM and got:
Wipers:
16: 0.75V
GEM:
10: 12.08V
20: 11.91V
25: 11.70V
26: 0.04V
28: 0.01V
Note: All of the fuses were checked with the key turned to accessories after I started the truck to verify the wipers weren't working and the wipers turned on for 16
I'm hoping that someone on this forum can confirm what I'm thinking about it being the GEM and possibly the right parts number for the GEM before I drop the money to get a GEM module
Azscort
Utah
I am having a similar problem, how did you reset the GEM?
Ravenmer
Washington, USA
Mazda B3000
I tried leaving the negative cable off of the battery for like 30 minutes and physically disconnecting the GEM for a couple minutes as well. Neither of these worked for me though so I ended up finding a GEM off of EBAY and that did it. If you do that make sure to match the code on what you want to buy with your current GEM.
Azscort
Utah
That’s just it, I can’t find one that is exact. Mine says F57B-14B205-EH, I can match everything but the EH. Any idea what that specifies?
Ravenmer
Washington, USA
Mazda B3000
First 5 are pretty much the make, model and year.
Middle group is the part - GEM.
The last two digits are a combo of Manual/Auto transmission and manual/power windows. Mine was a manual trans with manual windows and was an EE if that helps.
Also did you check if you got a 10 amp fuse in slot #26? That would be the easiest fix that people seem to have for this problem.
Azscort
Utah
Fuse is good, is your truck a 4x4? I head that matters with the GEM as it controls the transfer case although my transfer case is manual.
Ravenmer
Washington, USA
Mazda B3000
Yeah mine is a 4x4
Kirby N.
March Truck of The Month
