Possible help needed
River22
Colorado
Ford explorer
Hey yall, may not be a ranger but i have a 1996 ford explorer sport v6 4.0l and i cant shift into 1st with the shifter on the column but i can shift into every other gear just fine. Just cant access 1st gear and in drive every gear works fine. Also i cant get into 4Lo unless i go into reverse first then once i go back into 2wd the 4x4 and 4lo will flash at me and im stuck in 2wd unless i play with ignition for a lil bit. Any advice im lost
19Walt93
3,258
Canaan,NH
351
3"
235/55R16
Is the shift linkage loose?
Bronc3
ASE Certified Tech
23
Zero Gulch, Floriduh
Supercab FX4
3"
Do the same two T40 bolts on the column come loose on the Explorer like they do on the Ranger?
River22
Colorado
Ford explorer
That’s actually exactly what it was but no point in messing with it now cause im gonna have to put a whole new drive train in my truck
Eddo Rogue
1,619
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Put a for sale sign on it. Buy a new used truck with less problems. Life is short.
