2.3L ('02-'11) Possible EGR problem
2006Fusion2.3
South Carolina
Ford Fusion
It’s a 2.3 duratec with the electric egr and just need to know the resistance values between the pins to test it and make sure it’s bad
Blmpkn
Toilet enthusiast
6,350
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
@RonD knows everything, perhaps he can help.
8,296
I don't know this one, lol
Ford/Mazda used a Stepper motor, its like a "digital motor", a certain voltage "pulse" will cause the motor to turn XX degrees, so quite useful for this application
But I have no idea what would be correct test for these
You could test contact to case, if any are 0 ohms then there is an internal short to the metal case and its bad
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There is a magical light on your dash that will tell you whats wrong. There's like 14 codes for the EGR... which do you have?
I've worked on a ton of duratecs and have yet to see a bad egr solenoid.
2006Fusion2.3
South Carolina
Ford Fusion
I forget the actual codes I have to run them again. But it idles super low and like shit and other times super high because of a vacuum leak
Kirby N.
March Truck of The Month
